Debuging QCAD C++ source code
miro
Post by miro » Tue Feb 27, 2018 2:13 pm
Following this link https://www.qcad.org/en/component/conte ... om-sources, I have been able to build QCAD from Sources. It generates qcad exe in release folder.
I want to be able to debug qcad from sources C++, so I run qcad, and in QT Creator I try to launch debugging with attach mode, but it does'nt work.
Could you let me know how I can achieve that ?
Thanks.
Re: Debuging QCAD C++ source code
Post by andrew » Wed Mar 07, 2018 12:26 pm
I'm afraid I can't help with this, we don't develop on Windows. I would imagine that it should work though..
