Using offset in a script
RR88
Post by RR88 » Sun Apr 29, 2018 7:25 am
Hello.
I want to create a new entity from the offset of an existing entity in my drawing. How can I do this in a script? More precisely, how can I specify the distance and the side where the offsetted shape should be? It should work without a user interactivity respectively a mouse event.
Regards.
Gentoo/Linux, QCad 3.20 Prof.
RR88
Re: Using offset in a script
Post by RR88 » Sun Apr 29, 2018 3:01 pm
I tried this code:
var doc = getDocument();
var di = getDocumentInterface();
var itms = doc.queryAllEntities();
var itm = doc.queryEntity(itms[0]);
var s = itm.getPolylineShape();
var offs = s.getOffsetShapes(.5, 1, RS.LeftHand);
Am I right, that getOffsetShapes returns nothing because I'm using the trial version? https://github.com/qcad/qcad/blob/fe6ef ... .cpp#L1897 seems to be empty.
Post by andrew » Mon Apr 30, 2018 9:01 am
getOffsetShapes is only implemented for simple shapes like lines, arcs, circles and ellipses.
Offsetting polylines requires more information (join type) and can take multiple polylines as input.
If QCAD Professional (or indeed a QCAD Professional trial version) is running, you can offset polylines from a script as follows:
// distance: Distance of the offset
// number: Number of offsets to create
// pos Position indicating side of offset (see also setForceInside, setForceSide)
// joinType Join type for sharp corners (RS.JoinRound, RS.JoinMiter)
// preview True for preview mode (fast but not complete)
var worker = new RPolygonOffset(distance, number, pos, joinType, preview);
// optionally: force side and ignore pos:
worker.setForceSide(RS.LeftHand);
// add input polylines:
worker.addPolyline(polyline1);
worker.addPolyline(polyline2);
worker.addPolyline(polyline3);
var resultingPolylines = worker.getOffsetShapes();
Note: This is currently not part of the public QCAD API.
RR88
Post by RR88 » Mon Apr 30, 2018 6:08 pm
Thanks for your answer.
andrew wrote: Note: This is currently not part of the public QCAD API.
... but it should be.
Here is my working script https://github.com/zippy84/lc-qcad/blob ... offsets.js, for those who are interested in.
RR88
Post by RR88 » Sun May 06, 2018 5:12 pm
I found a special case where RPolygonOffset does not work proper. My drawing is attached and my script is:
var entities = doc.queryAllEntities();
var ent = doc.queryEntity(entities[0]);
var blkId = ent.getReferencedBlockId();
var itms = doc.queryBlockEntities(blkId);
di.setCurrentBlock(blkId);
var itm = doc.queryEntity(100);
var newShapes = [];
for (var k = 0; k < itm.countSegments(); k++) {
    var seg = itm.getSegmentAt(k);
    if (isLineShape(seg)) {
        if (seg.getLength() < 1e-5) {
            continue;
    newShapes.push(seg.clone());
itm.setShape(new RPolyline(newShapes));
var op = new RModifyObjectsOperation();
itm.reverse();
op.addObject(itm, false);
di.applyOperation(op);
var worker = new RPolygonOffset(.15/2, 1, RVector.invalid, RS.JoinMiter, false);
worker.setForceSide(RS.RightHand);
worker.addPolyline(itm.castToShape());
var offs = worker.getOffsetShapes();
Itm is defined as:
RLine(RShape(address: "0x104f9fc0"), startPoint: RVector(7.46514, -3.58589, 0, true), endPoint: RVector(7.46514, -16.9197, 0, true))
RLine(RShape(address: "0x4fee5460"), startPoint: RVector(7.46514, -16.9197, 0, true), endPoint: RVector(15.0485, -16.9197, 0, true))
RLine(RShape(address: "0x8651390"), startPoint: RVector(15.0485, -16.9197, 0, true), endPoint: RVector(15.0485, -3.58647, 0, true))
RArc(RShape(address: "0x75c84000"), center: RVector(11.256, -14.0402, 0, true), radius: 11.1204, startAngle: 70.0601, endAngle: 109.931, startPoint: RVector(15.0485, -3.58647, 0, true), endPoint: RVector(7.46514, -3.58589, 0, true), sweep: 0.695883, reversed: false)
RLine(RShape(address: "0x162a2f30"), startPoint: RVector(7.46514, -3.58589, 0, true), endPoint: RVector(7.46514, -3.58589, 0, true))
It is obviously not clean, because of the zero-length line at the end.
Why is offs empty and is there another way to remove the line?
Err.dxf
(105.03 KiB) Downloaded 55 times
RR88
Post by RR88 » Mon May 07, 2018 3:45 pm
Also this does not work:
var pl = new RPolyline();
            continue;
    pl.appendShapeAuto(seg.clone());
pl.convertToClosed();
pl.reverse();
worker.addPolyline(pl);
RR88
Post by RR88 » Mon May 07, 2018 4:23 pm
This script works:
var a = [];
            continue;
    a.push(seg.clone());
a.push(a.shift());
for (var i = 0; i < a.length; i++) {
    pl.appendShapeAuto(a[i]);
pl.reverse();
var op = new RAddObjectsOperation();
op.addObject(shapeToEntity(doc, offs[0].data()), false);
Note that the arc-shape is not longer the last element in a. It looks like a bug.
