Signals and Slots in ECMAScript
Post by andrew » Fri May 25, 2018 10:06 pm
From a QCAD user:
How can I use signals and slots in QCAD scripts, for example to detect if the text in a line edit has changed?
Re: Signals and Slots in ECMAScript
Post by andrew » Fri May 25, 2018 10:07 pm
Example:
var le = new QLineEdit();
// call this.validate() on text changes:
le.textChanged.connect(this, "validate");
// call an inline function on text changes:
le.textChanged.connect(this, function(text) { qDebug("text is now: " + text); });
See also:
http://doc.qt.io/archives/qt-4.8/scripting.html
RR88
Post by RR88 » Sat May 26, 2018 4:36 pm
How can I detect the sender? Object.sender() does not exist.
Gentoo/Linux, QCad 3.20 Prof.
Post by andrew » Tue Jun 05, 2018 1:48 pm
I don't think that's available in scripts. Usually a slot is not (and probably shouldn't have to be) interested in the sender.
