util qcad functions
sarlaa
util qcad functions
Post by sarlaa » Mon Jun 18, 2018 7:33 pm
Can you tell me if in qcad exists functions for :
-Get the fusion of 2 lines ?
-check if a point is included in a shape ? (can be on shape lines or inside)
-Check if a line is included in a shape ? (can be on shape lines or inside)
And give me example of use if it exists.
Thanks.
Re: util qcad functions
Post by andrew » Tue Jun 19, 2018 11:44 am
Please elaborate. Do you want to create a polyline? Do you want to combine two line segments into one line? ...?
sarlaa wrote:-check if a point is included in a shape ? (can be on shape lines or inside)
For a polyline, you can use RPolyline::contains:
polyline.contains(point, true, tolerance);
Second parameter is true to count points on the polyline as being 'inside'.
sarlaa wrote:-Check if a line is included in a shape ? (can be on shape lines or inside)
You can use RPolyline::containsShape:
polyline.containsShape(shape);
Note that this excludes shapes on the polyline. These cases would have to be handled separately.
sarlaa
Post by sarlaa » Tue Jun 19, 2018 11:59 am
Thanks it's useful.
For my first point (fusion of 2 lines), in fact I want to combine two line segments into one line.
Post by andrew » Tue Jun 19, 2018 12:04 pm
OK. There is no special function for this in the QCAD API.
sarlaa
Post by sarlaa » Tue Jun 19, 2018 12:07 pm
Ok.
for checking if polyline contains point I tried :
 var plItem = new RPolyline();
  var pointsItem = [new RVector(0,20), new RVector(20,20), new RVector(20,0), new RVector(0,0)]
  plItem.setVertices(pointsItem);
  var point = new RVector(10,10)
  var check = plItem.contains(point, true); //check is false
I get false, is there something I do wrong ?
sarlaa
Post by sarlaa » Tue Jun 19, 2018 12:13 pm
I see my error had to do :
var pointsItem = [new RVector(0,20), new RVector(20,20), new RVector(20,0), new RVector(0,0), new RVector(0,20)]
It works. Thanks
