RAddObjectsOperation
pmbrull
Post by pmbrull » Fri Sep 28, 2018 11:12 am
Hello and thank you for your time,
When using RAddObjectOperation, is it possible to also change the REntity properties?
What I am trying to achieve is:
var hatch = new RHatchEntity(document, hatchData);
hatch.setColor(new RColor(0, 0, 255, 1));
hatch.setLayerId(MyLayerId);
var op = new RAddObjectOperation(hatch, true, true);
di.applyOperation(op);
However, the object that gets added still keeps the default properties of belonging to layer 0 and being colored by layer.
Thank you,
Pere
Re: RAddObjectsOperation
Post by andrew » Fri Sep 28, 2018 11:22 am
The second argument of the constructor means "useCurrentAttributes", i.e. ignore the attributes assigned to the entity and use the current attributes. This is also the default, so you need to change this to false to keep the attributes assigned to your entity:
var op = new RAddObjectOperation(hatch, false);
pmbrull
Post by pmbrull » Fri Sep 28, 2018 11:38 am
Works like a charm,
