toolbar name as tooltip
- Registered Member
It would be extremely helpful if when you hovered over a toolbar at the position where you can drag it, that the name of the toolbar is displayed. It can be quite time consuming trying to figure out which toolbar it is that you want to turn off. It's basically just trial and error now.
Re: toolbar name as tooltip
Toolbars are pretty much arranged the same way as the menu structure.
The Edit toolbar holds things from the Edit menu.
The Draw Polyline toolbar displays tools from the Draw Polyline menu.
It is thus not blind trial and error.
There is not much place on a toolbar that is not covered by tool buttons.
But I agree that it is probably a little effort to add some sort of tooltip message to the beginning of each toolbar.
The best place to file features requests is Bugtracker: https://qcad.org/bugtracker/
You need a separate account there or make a new one.
