Small details
Please use this forum to post feedback and suggestions related to QCAD Professional 3.0.
Small details
Postby klavs » Mon Nov 07, 2011 9:02 am
Hi - just downloaded qcad 3 - rc1 - for Linux.
1) When I want to select multiple lines - holding ctrl and clicking on the second (and third etc.) does not add them to the selection as it did with qcad2 :(
2) When in printing preview mode - ctrl+p doesn't work. (I have to select it under file to print).
3) The icons for lines etc. are absurdly huge - but that maybe just me - on a 1920x1080 resolution on a 17" screen.
p.s. would you prefer me to open bugs - or is this feedback method fine?
klavs
Postby klavs » Mon Nov 07, 2011 9:11 am
bug: When trying to edit the text on a 90 degree angle text= "(53 sk. + 57mm)..." - it pops up a QT debugger window instead, saying it can't find element simple text.
Here's the dxf:
http://vsen.dk/files/hus/murer/hus-faca ... tplade.dxf
klavs
Postby klavs » Mon Nov 07, 2011 9:13 am
Also - when trying to open a drawing edited in qcad3, in qcad2 - it's screwed up the layer names (when they have æøå - ie. danish characters in them) - and also layer colors is suddenly changed.
klavs
Re: Small details
Postby andrew » Mon Nov 07, 2011 9:30 am
klavs wrote:1) When I want to select multiple lines - holding ctrl and clicking on the second (and third etc.) does not add them to the selection as it did with qcad2 :(
Please try Shift instead.
klavs wrote:2) When in printing preview mode - ctrl+p doesn't work. (I have to select it under file to print).
Bug report:
http://www.ribbonsoft.com/bugtracker/in ... ask_id=371
klavs wrote:3) The icons for lines etc. are absurdly huge - but that maybe just me - on a 1920x1080 resolution on a 17" screen.
Edit - Application Preferences - Widgets - CAD Tool Bar - Icon Size
klavs wrote:p.s. would you prefer me to open bugs - or is this feedback method fine?
Please use the bug tracker whenever possible, thanks. Please search for existing task (including closed ones) before opening a new one.
klavs wrote:When trying to edit the text on a 90 degree angle text= "(53 sk. + 57mm)..." - it pops up a QT debugger window instead, saying it can't find element simple text.
Duplicate, closed:
http://www.ribbonsoft.com/bugtracker/in ... ask_id=369
klavs wrote:Also - when trying to open a drawing edited in qcad3, in qcad2 - it's screwed up the layer names (when they have æøå - ie. danish characters in them) - and also layer colors is suddenly changed.
Bug report:
http://www.ribbonsoft.com/bugtracker/in ... ask_id=372
[Edit: I read that the wrong way around. QCAD 2 will not be fixed to be forward compatible with QCAD 3, so I closed the task again.]
Return to QCAD 3.0 Suggestions and Feedback
