save as - qcad3.0 rc4 crash
Please use this forum to post feedback and suggestions related to QCAD version 3.
Postby mandrena » Wed Mar 21, 2012 6:52 am
hi,
i've just installed and use version in object, when i try to make "save as" qcad crash. :?:
thanks for suggestion and solution
mandrena
Re: save as - qcad3.0 rc4 crash
Postby clive » Wed Mar 21, 2012 11:44 am
mandrena wrote:hi,
mandrena
RC4 is a release candidate of version 3 and is still being tested 'out here' by users.
Version 2 is the current 'stable' version so you may want to use this for now if its for productive work.
Use this for reporting bugs:
http://www.ribbonsoft.com/bugtracker/
you will need to register to use it and make sure you include your operating system in the feedback -for example windows 7 -64 bit etc...
clive
solved
Postby mandrena » Wed Mar 21, 2012 3:39 pm
i've solved problem making uninstall and new install of rc4, setting to default drivers for nvidia quadro 600 and reboot.
Problem solved.
Thank you
mandrena
Return to QCAD 3 Suggestions and Feedback
