Auto center function
Please use this forum to post feedback and suggestions related to QCAD Professional 3.0.
Postby J-J » Thu Apr 26, 2012 7:51 am
When working on very large drawings I sometimes have to print only a small section. It would be handy to be able to have the option to apply the auto center function only to the said section.
J-J
Re: Auto center function
Postby Husky » Thu Apr 26, 2012 9:03 am
J-J wrote: .... only to the said section.
Sounds good - but how should QCad know what the "said section" is.
Workaround?
Print preview,
One Page,
Move Paper Position to the "said section",
maybe adjust scale,
Would that work for you?
Postby clive » Thu Apr 26, 2012 10:01 am
J-J
I agree and definitely need this for some of the plans I work on. See image.
I have previously added a feature request for printing only the selected area in model space.
http://www.ribbonsoft.com/bugtracker/in ... &pagenum=2
clive
Postby clive » Thu Apr 26, 2012 10:08 am
Forgot to mention my 'workaround'
In model space drag and select with the cursor the area you to print only, Edit > copy this and then paste this in a new drawing!
It works :wink:
clive
Postby clive » Thu Apr 26, 2012 11:27 am
I thought this topic had come up before - see here:
viewtopic.php?f=32&t=1861
Andrews 'workaround'.
clive
Postby J-J » Thu Apr 26, 2012 2:24 pm
I do that manually. I drew my section on a new layer, hoping this would do it, but auto center takes the whole drawing, even if everything else is masked. Let's keep that for a future edition, that is not critical!
Thanks for the comments.
J-J
Return to QCAD 3.0 Suggestions and Feedback
