QCAD 3.0.3 snapshot release feedback - Polyline Simplify
Please use this forum to post feedback and suggestions related to QCAD version 3.
Postby clive » Tue Nov 06, 2012 2:37 pm
Thanks :D
Another great feature added to the Polyline tool set is polyline > Simplify.
This feature can dramatically reduce the number of points in a polyline while keeping its 'basic' shape - very useful indeed when you need to laser cut lots of
road/contours out :cry:
and I would also imagine it would be useful for rendering large line/map files using SVG in a browser (I `m no expert with roads or map contour drawings - someone will need to test this, hint, hint :wink: ).
I can think of endless possibilities for using this tool in complicated technical drawings in all fields!
Here is my example test:
I draw a road with a polyline which has 663 points.
road 1.png (15.69 KiB) Viewed 776 times
I select my polyline and use Polyline > Simplify tool and change my Angle tolerance to 100 (just to show the difference here).
Tick the Green tick button and...
road 2.png (26.24 KiB) Viewed 776 times
This is my Polyline after simplification - now with only 200 points and ' more or less' keeping it`s basic shape.
road 3.png (14.05 KiB) Viewed 776 times
clive
Return to QCAD 3 Suggestions and Feedback
cron
