Make a sub layer it's own layer in it's own right!
Moderator
Post by Clive » Mon Nov 10, 2014 5:24 pm
When creating a sublayer and assigning a parent layer for it - I think afterwards there should be the option to make the sublayer a layer in it's own right, without any parent layer if required.
Re: Make a sub layer it's own layer in it's own right!
Post by andrew » Tue Nov 11, 2014 9:03 am
1. Click the sub layer
2. Edit the layer
3. For the parent layer, choose the empty entry in the combo box
Screen Shot 2014-11-11 at 09.01.44.png (49.13 KiB) Viewed 7220 times
Moderator
Post by Clive » Tue Nov 11, 2014 10:27 am
Thanks Andrew, I can understand the logic now that you've explained it, however I think it would be useful to have an 'Edit Layer' option in the layer drop down list instead of clicking a blank field. I must admit at the time I didn't think of doing this and newcomers may miss this altogether.
Post by andrew » Tue Nov 11, 2014 10:31 am
Clive wrote:I think it would be useful to have an 'Edit Layer' option in the layer drop down list instead of clicking a blank field.
Not sure I follow. Are you suggesting that the empty entry in the combo box should contain the text "Edit Layer"? Why? e_confused
Moderator
Post by Clive » Tue Nov 11, 2014 10:42 am
Don't worry Andrew, it all makes sense ... not really sure what I was thinking ... need a coffee :lol:
Post by andrew » Tue Nov 11, 2014 10:53 am
OK :)
