Visibility of tools feedback
Moderator
Post by Clive » Thu Nov 20, 2014 3:50 pm
Hi Andrew
Fantastic improvement with the adjustment of visibility of tools in menus and toolbars 8) .
Suggestions:
Icons are neded for:
Focus on Command line and Focus on options toolbar.
Icons needed.png (223 Bytes) Viewed 13701 times
Re: Visibility of tools feedback
Post by andrew » Thu Nov 20, 2014 3:56 pm
Yes, there are still quite a few tools without icons. These will be added over time when time permits, or perhaps some will be added by the QCAD community (any Inkscape artists out there? 8) ).
Jef
Post by Jef » Thu Nov 20, 2014 11:08 pm
This doesn't seem to be working correctly for me (QCAD Pro Linux 3.7.2). I tried adding some tools to the CAD toolbar but they don't show up, even after a reboot. Also, the Reset icon has vanished. The toolbar is there, but empty.
Post by Husky » Fri Nov 21, 2014 2:04 am
Jef wrote:This doesn't seem to be working correctly for me (QCAD Pro Linux 3.7.2). I tried adding some tools to the CAD toolbar but they don't show up, even after a reboot. Also, the Reset icon has vanished. The toolbar is there, but empty.
Yes, I was also struggling to bring my "old settings" back. But now it seems to work ....
Regarding the vanished Reset Icon: I experience the same problem (Windows). You have to tick (again?) the Tool bar visibility.
Post by Husky » Fri Nov 21, 2014 10:29 am
andrew wrote:... or perhaps some will be added by the QCAD community (any Inkscape artists out there? 8) ).
Artist - not me! :shock:
But maybe this is better than nothing ... 8)
FOB.svg
(9.53 KiB) Downloaded 773 times
FCL.svg
(6.47 KiB) Downloaded 790 times
Moderator
Post by Clive » Fri Nov 21, 2014 11:29 am
Hey Husky, not bad at all :wink:
Moderator
Post by Clive » Fri Nov 21, 2014 12:06 pm
Andrew, I probably use the Modify toolset the most out of all the tools available, so I always have this toolset docked for easy access. With your newly improved feature for controlling the visibility of toolbars I decided to hide the Modify toolset from the main CAD toolbar ... makes sense to me - now that I can do this :wink:
In practice this was easily achievable however I had to go through everyone of the tools to untick the visibility from the CAD toolbar, to my way of thinking it would be easier to just select the 'parent' icon for the modify tools and untick the visibilty and this would then in return make all other tools within this toolset invisible avoiding the need to manually go through all of them one by one. Of course I am only suggesting this works for all parent icons for the toolsets!
Post by andrew » Fri Nov 21, 2014 12:59 pm
This should indeed just be one tick to remove the modify button from the CAD tool bar:
Screen Shot 2014-11-21 at 12.55.35.png (185.09 KiB) Viewed 13978 times
Of course the individual modification tools will still be in their respective CAD tool bar panel, but since you don't have a button anymore to show that panel, that is irrelevant.
Moderator
Post by Clive » Fri Nov 21, 2014 1:45 pm
Thanks for the reply Andrew, my point is that if you hide the parent icon for the modify tools it doesn't hide the other tools if you then use one of the modify tools that you previously didn't 'untick' the visibility for, here's a image to help explain this.
Here you can see the modify toolbar docked and when using it you can see the break out tool in two places! hiding the parent icon for the modify toolset didn't hide all the other tools.
Query visibility.png (23.33 KiB) Viewed 13660 times
Post by andrew » Fri Nov 21, 2014 1:51 pm
Thanks, I see what you mean now. The problem is that some tools automatically show certain CAD tool bar panels. That could certainly be improved, yes.
Moderator
Post by Clive » Fri Nov 21, 2014 2:09 pm
andrew wrote:Thanks, I see what you mean now. The problem is that some tools automatically show certain CAD tool bar panels. That could certainly be improved, yes.
Okay thanks Andrew.
Jef
Post by Jef » Fri Nov 21, 2014 10:09 pm
Husky wrote:Regarding the vanished Reset Icon: I experience the same problem (Windows). You have to tick (again?) the Tool bar visibility.
Thanks, Husky. This did the trick.
