Hotkeys to change Rectangle with Size reference point [1-9]
I'm a little confused with hotkeys to change Rectangle with Size reference point with keys 1 to 9 : when using the numeric keypad, top and bottom are reversed, i.e '7' is on top left on the keyboard, and yields a bottom left reference point on the drawing ... Maybe it would be more logical to invert '1 2 3' and '7 8 9' use ?
Re: Hotkeys to change Rectangle with Size reference point [1
The hotkeys work in a clock wise manner starting from top left and work its ways down like if you were reading text. Not all users have a numeric keypad, I think Andrew can chime in on this as well
