Paste Rotation Options
Moderator
Post by Clive » Fri Jan 30, 2015 4:23 pm
I think it would be good to have an option to rotate to 360 degrees. Currently 330 degrees is the greatest defined, unless you type in your own angles of course!
Paste Rotation 360.png (24.38 KiB) Viewed 6501 times
Re: Paste Rotation Options
Post by andrew » Fri Jan 30, 2015 4:29 pm
Do you have a use case for this?
Rotating 360 degrees would be the same as rotating 0 degrees (i.e. not rotating at all).
Moderator
Post by Clive » Fri Jan 30, 2015 5:29 pm
Yes of course, silly me :roll:
Post by andrew » Fri Jan 30, 2015 5:46 pm
It's Friday... :)
Moderator
Post by Clive » Fri Jan 30, 2015 11:14 pm
andrew wrote:It's Friday... :)
yeah...something like that, been a busy week :lol:
