(De-) Select Polgon TP
Moderator
Post by Clive » Sat Jan 30, 2016 6:19 pm
When using the (De-) Select Polgon TP tool I would like the option to be able to hold the 'shift' key down while selecting as many further polygon selections as I need to.
Hope this makes sense :roll:
Re: (De-) Select Polgon TP
Post by Husky » Sat Jan 30, 2016 8:16 pm
Clive wrote:Hope this makes sense :roll:
Yes - that makes sense. Until you get this additional feature you could use the Option bar / Mode / "Add to the current selection":
Moderator
Post by Clive » Mon Feb 01, 2016 3:03 pm
Husky wrote: Until you get this additional feature you could use the Option bar / Mode / "Add to the current selection":
Thanks, yes this is what I'm currently doing ... I'm just looking for quicker ways I guess :wink:
