QCAD crashes when using morph
TSG
Post by TSG » Fri Jun 29, 2018 6:55 am
Hi all
I'm using QCAD 3.21.0 on an iMac late 2012 with macOS Sierra 10.12.6
When testing the new function "morph" QCAD crashes when selecting the (first) polyline.
It doesn't matter which kind of polyline I want to select. QCAD crashes without any error report completely.
I've no idea what's going wrong. Please help.
Thomas
morph-test2.dxf
(283.68 KiB) Downloaded 423 times
morph-test.dxf
(285.33 KiB) Downloaded 426 times
Re: QCAD crashes when using morph
Post by andrew » Fri Jun 29, 2018 8:30 am
Thanks. Looks like a deployment issue. An update is on the way:
http://www.qcad.org/bugtracker/index.ph ... sk_id=1774
Post by andrew » Fri Jun 29, 2018 10:25 pm
QCAD 3.21.1 is now available with a fix.
