≈ in a Dim Label?
Use this forum to ask questions about how to do things in QCAD version 3.1/3.0
≈ in a Dim Label?
Postby Husky » Wed Mar 20, 2013 8:57 am
Selected Dim ... Property editor - Geometry - Label:
How can I put a in the Label? ≈<> doesn't works 8)
Thanks for help!
Re: ≈ in a Dim Label?
Postby andrew » Wed Mar 20, 2013 10:54 am
The font used for dimension labels does not contain the 'Almost equal to' symbol (≈).
I've attached a font update. Drop it into the 'fonts' sub directory of your QCAD installation and replace the existing standard.cxf.
Standard.cxf
(27.24 KiB) Downloaded 22 times
Postby clive » Wed Mar 20, 2013 12:58 pm
In addition, if you want to use symbols which are not in the standard.cxf. set for dimension labels this little 'work around' may help :wink:
My example:
1. Select the dimension in question.
2. Use the Explode tool.
3. In the property editor - select only the text and change the Font Name to something other than standard e.g. Arial.
4. Copy/paste, add your symbol in the contents field and hey presto -job done :wink:
applying 'one off' symbols.png (15.23 KiB) Viewed 318 times
If you have several to change, use the property editor to target your selections accordingly, explode then target selection again to the text again followed by the same above method!
applying 'one off' symbols 2.png (2.57 KiB) Viewed 318 times
clive
Postby Husky » Wed Mar 20, 2013 6:51 pm
andrew wrote:The font used for dimension labels does not contain the 'Almost equal to' symbol (≈).
Perfect - works - Thank you!
Any chance to get it also in the "Insert Symbol" menus ... maybe with one of the next QCAD updates .... :roll:
Postby Husky » Wed Mar 20, 2013 7:05 pm
clive wrote:In addition, if you want to use symbols which are not in the standard.cxf. set for dimension labels this little 'work around' may help :wink:
Hi Clive - thank you for your work around - but I try to avoid a "Exploded Dimension". I like to have a working automatic dimensioning in my drawings because I can always trust the displayed figures 8)
Postby clive » Wed Mar 20, 2013 7:56 pm
Husky wrote:Hi Clive - thank you for your work around - but I try to avoid a "Exploded Dimension". I like to have a working automatic dimensioning in my drawings because I can always trust the displayed figures 8)
Absolutely, I agree - this workaround was more for ' one off ' symbols that could be added now and again! :wink:
clive
Return to QCAD 3.1/3.0 'How Do I' Questions
