How do I lengthen the dimension line?
Postby caigner » Mon Apr 22, 2013 7:45 pm
I added a diametric dimension to a circle and wanted to move the number outside the circle. Moving the number was no problem, but the line of the diametric dimension did not "grow" with the moved dimension text.
So here is my question: How do I lengthen the dimension line?
caigner
Re: How do I lengthen the dimension line?
Postby Husky » Tue Apr 23, 2013 7:14 am
Hi caigner,
in this case you have to explode the dimension - then you can use the lengthen tool. I think this is just a workaround - but I can't see right now a better solution.
Maybe worth a feature request ..... :wink:
Postby Clive » Tue Apr 23, 2013 10:22 am
In addition:
You will find that when you select or explode/select entities in QCAD ( in this case a dimension entity! ), you will also be able to 'click and drag' a reference point to a new coordinate position.
Before
Diametric - modify 1.png (2.23 KiB) Viewed 2376 times
After
Diametric - modify 2.png (4.86 KiB) Viewed 2376 times
Postby caigner » Sat Apr 27, 2013 6:14 pm
Thanks! Works well enough. But you are right, it will be a great feature. :-)
caigner
Users browsing this forum: Bing [Bot] and 3 guests
