[solved] Question about making a block library.
Tegulf
Post by Tegulf » Sun Feb 04, 2024 8:05 pm
Hi
There is probably a tutorial for this but I'm not sure what word i should search for.
My plan is to use Qcad to draw standard symbols on top of different drawings. Is there a way to draw a symbol, and save it to a type of library in the program. That can be opened next time I'm in a new drawing?
Is is symbols, blocks or anything else i should search for?
Re: Question about making a block library.
Post by CVH » Sun Feb 04, 2024 8:37 pm
Library items are the keywords to look for.
See: https://www.ribbonsoft.com/doc/qcad/lat ... em_en.html
Post by Husky » Sun Feb 04, 2024 8:40 pm
Hi
Yep, you can find the tutorial here: :wink:
https://qcad.org/en/tutorial-working-wi ... rt-library
Tegulf
Post by Tegulf » Sun Feb 04, 2024 9:02 pm
Thank you very much :D
