Corkscrew or streching an ellipse
Re: Corkscrew or streching an ellipse
Post by CVH » Sun Mar 17, 2024 8:39 am
Nice, thank you ...
Probably the best solution up to now. 8)
You have to admit that what Chips&Chips presented on Feb 29 comes very close visually.
I don't think that it must be exact for the intended purpose ... :wink:
One of the problems I see is that in QCAD splines end normal.
Your start and end curvature is thus not entirely correct between the last 2-3 fitpoints at either side.
Solution:
Overdo it at least 2 extra points at both ends and trim the fit-point spline at the Y axis.
That will result in a control point spline with proper end tangents.
An unanswered question is rendering load.
How much more lag do 8 splines of degree 3 induce compared to 16 ellipses and that for numerous helix blocks inserted on drawing?
And how does that compares with your final spline with 193 fit-points (8x24+1)?
Selecting a 10 by 10 array of such blocks takes about 2-3 seconds on my old Pentium 7.
Some quick test tells me that the spline block is faster ... :P
Last question:
What type of projection is this?
https://en.wikipedia.org/wiki/3D_projection
Your X axis is horizontal and both your Y and Z axis are vertical ... :?
DerekGove
Post by DerekGove » Sun Mar 17, 2024 3:15 pm
Nice, thank you ...
- Cheers. you're welcome. I'm sure some clever person could write a script to do the same thing, but that's how a 3D view of a helix should be constructed— with pencil and paper at least. And it's easy enough to use in cases where a "Draw helix in 3D" button doesn't exist. : :D
- Yeah, totally agree. His solution was nice visually, and looked good for a diagramatical representation. Certainly a nicer result than the traditional simplified version of a helix...
edit: Worth noting that the original poster, sancyk, was asking about a helix in isometric, so I hope this has been helpful for them, even though Chips&Chips may not have needed an accurate solution.
And these aren't even in 3D. LOL
One of the problems I see is that in QCAD splines end normal....
-Yeah. If I was doing something where I wanted the end tangents correct, I'd add an extra revolution on each end, and then cut them off where I needed.
- Well, I'm not running QCAD on a Pentium 7, so you're in a better position to judge that. ;) But looking at the traditional 'simplified' helix, this method could even be massively simplified to a dozen, or even fewer straight lines per rotation. Depends how detailed a diagram or representation needs to be, and how prominently the helix will feature.
Here's one with 8 lines per rotation (not even a spline), which would be acceptable in certain circumstances, and another with only 4 lines per rotation, which is about as bare-bones as you can get. It'll render really, really fast, but I don't think even I'd use it except under duress. :)
I only really threw these together to illustrate that the construction can be as detailed or as simple as required.
Last question:
- That last one in my original post was a dimetric projection. (I'd have normally done an example in isometric, but I wanted to try and match the spacing in Chips&Chips' drawing, so 'reverse engineered' the minor axis of the ellipse to match)
In both dimetric and isometric, once the view is rotated 45 degrees and then foreshortened, it is still a perfect ellipse, (as there is no perspective distortion) so it doesn't matter that it was drawn in such a way that it appeared that the x, y and z axes were horizontal and vertical. In Chips&Chips' drawing, he had the starting point of the helix 'front and centre', so I did my drawing to match that.
Here's the standard construction (with an unneccessary bounding square added for clarity), and it converted into isometric.
As you can see, there isn't a 30/60 line intersecting the ellipse at a point where I wanted it, at the lowest point of the circle.
So if I rotate the circle and lines by 45 degrees first, and then convert/foreshorten it for isometric, The ellipse is identical, but this time I have my construction lines exactly where I want.
edit: Worth noting too, that as I ended up using a circle divided into 24 parts, not the 12 I would use if drawing one by hand, there's no need to rotate it 45 degrees at all.
Planometric drawings are easy, because the 'top' view is a perfect circle anyway.
For auxiliary projections, trimetric, cavalier or cabinet, (and I were doing it by hand) I'd probably use the enclosed parallellogram method to locate my key points for my base circle that I project the helix up from:
But of course, QCAD has some great built in functions to convert orthographics into those types of drawings.
Cheers,
Derek
QCAD Version 3.29.4 : Windows 10
