What's Spline in Leader properties?
r0berts
Post by r0berts » Tue Mar 26, 2024 4:02 pm
A newcomer. Apologies, what is the meaning of spline under leader properties. I understand that one cannot make arrows on spline curves, but this property appears to suggest otherwise? In any case my aim is to draw a diagram where I would have some curved lines with arrows at the end. Thanks!
System - manjaro linux, QCAD - professional version 3.29.4
Re: What's Spline in Leader properties?
Post by andrew » Tue Mar 26, 2024 4:11 pm
Spline leaders are not supported at this point in QCAD.
I can confirm that this property currently has no function and is not stored when set.
P.S.: Please attach images to your post rather than hosting them on other sites where they will be eventually deleted.
r0berts
Post by r0berts » Tue Mar 26, 2024 4:35 pm
Thanks, not used to this phpBB took time to work out how to post images.
Post by CVH » Tue Mar 26, 2024 5:41 pm
r0berts:
Work around:
- Draw your spline.
- Draw a Leader with arrow somewhere. (Or a dimension for that matter)
- Explode the Leader and 'steal' the arrow deleting the rest ... :lol:
