Add Item to menu!
Prostreet
Add Item to menu!
Post by Prostreet » Wed Mar 27, 2024 11:36 pm
I'm probably wrong in stating that QCAD doesn't have an icon command to start "NPOINTS".
I always tap the space bar then type the command in.
I use it quite frequently to divide lines into uniform segments.
Version: 3.29.4.0 (3.29.4)
I would like to ask:
1. Is there a icon in the existing professional version?
2. If no, can it be done and if yes, how hard?
Any and all comments are appreciated.
Thank You.
Jerome
Re: Add Item to menu!
Post by Husky » Thu Mar 28, 2024 4:33 am
Yes.
Activate the toolbar for "Points" below:
Menu/View/Toolbars and Widgets/Draw/Points
Place the toolbar where it fits your workflow best.
Btw:
Instead space/commandline/command you could also use direct in an active Modelspace/GUI the shortcut: PN
Post by CVH » Thu Mar 28, 2024 7:47 am
For sure:
Perhaps you have turned off visibility in Menus, Toolbars and/or the Tool Matrix.
See: menu Edit .. Application Preferences .. General .. Tool Settings
Look up: Draw .. Point .. 'N points on Line' and verify if the visibility is not cleared.
