Block editor
Block editor
Postby S2BCROZ » Mon Oct 10, 2011 6:23 pm
How do I exit the block editior once in it? I click the pencil icon to edit a block but can't figure out how to exit and return back to the drawing.
S2BCROZ
Postby andrew » Mon Oct 10, 2011 6:43 pm
Make sure that the block list is visible (View - Toolbars - Blocklist).
After editing a block, double-click Model Space to edit the main drawing (model space) again.
Postby S2BCROZ » Mon Oct 10, 2011 7:00 pm
hmm, can seem to get it to work. I open my drawing, then from the block list I select a block and then choose the edit button, this opens the block. i make changes, then double click but it does not return me back to the main drawing.
S2BCROZ
Postby andrew » Mon Oct 10, 2011 7:06 pm
Double-click on the '*Model_Space' block or click '*Model_Space' and then click the button to edit the selected block.
For better understanding: Editing the main drawing is in fact nothing different than editing a block, the special root level block called '*Model_Space'.
Postby S2BCROZ » Mon Oct 10, 2011 7:11 pm
got it! thank you Andrew
S2BCROZ
cron
