Install of RC1
Install of RC1
Postby J-J » Wed Nov 02, 2011 5:10 pm
I just downloaded a copy of QCAD3-RC1. How can I install without it erasing ver 2.2?
platform Win7-64
JJ
J-J
Moderator
Postby andrew » Wed Nov 02, 2011 5:27 pm
QCAD 3 is a new, separate application that can live side by side with QCAD 2.
If you use the Windows installer, please make sure that you don't install QCAD 3 in the same directory where you have previously installed QCAD 2.
If you are not sure, download the ZIP file instead and extract it somewhere on your hard drive. This allows you to run QCAD 3 without installing the software.
RC1 install
Postby J-J » Wed Nov 02, 2011 6:44 pm
With the beta version, the installer did as you suggest and I could run both versions together. The RC1 installer detects QCAD 2.2 and does not give me an option to make another directory.
I will try the ZIP.
J-J
Moderator
