Persistant rulers
dwight
Persistant rulers
Postby dwight » Thu Nov 03, 2011 11:29 pm
How do you leave the measurement ruler on so if you have to move a line to be an exact distance away from another entity that is on an angle you have a guide.
For parallel vertical or horizontal lines a calculation can be done. This is to difficult if the lines or entities are on angle.
Dwight
Postby andrew » Fri Nov 04, 2011 7:40 am
Not exactly sure what you mean.
In general: use auxiliary constructions to construct your drawing. Calculations are very rarely necessary and not precise (unless you enter 12 decimal digits). There's for example a parallel tool to create a parallel with a given distance.
dwight
Postby dwight » Wed Nov 09, 2011 12:37 am
Ok, that does what I need to do. May not be the best way, but it works.
Dwight
