Pan using the middle mouse button
aksurf
Postby aksurf » Tue Jan 17, 2012 11:47 am
Does anybody know how to make panning using the middle mouse button possible again?
As it was in Qcad 2?
T.i.a.
Arwin
Moderator / Drawing Help
Postby Clive » Tue Jan 17, 2012 1:49 pm
Hi aksurf and welcome to the forum.
What operating system are you using?
aksurf
Postby aksurf » Tue Jan 17, 2012 2:26 pm
Tnx Clive!
I'm using Windows 7 and Logitech trackman wheel.
Postby Clive » Tue Jan 17, 2012 2:39 pm
aksurf wrote:Tnx Clive!
-no problem for me on desktop (win 7 -64) and my laptop (linux -ubuntu 11.10)!
-did you use the trackman with QCAD v2?
It could be that you need to re-configure your "trackball", have a look.
failing that use bug tracker to submit your bug at;
http://www.ribbonsoft.com/bugtracker/
You will need to register to use it!
aksurf
Postby aksurf » Tue Jan 17, 2012 2:48 pm
TNX Clive !!!
For putting me on the right track. :D
Reconfiguring my trackball-mouse did the trick!
Tnx & greetings,
Arwin
Postby Clive » Tue Jan 17, 2012 2:52 pm
aksurf
I forgot to ask the most basic of questions
Did you first go to >edit >Application preferences > graphics view >navigation
and then "check" -enable pan gesture!
Forgive me if you`ve already done this :D
aksurf
Postby aksurf » Tue Jan 17, 2012 2:57 pm
No problem,
Did try that setting but it didn't make a difference..
Postby Clive » Tue Jan 17, 2012 3:07 pm
aksurf wrote:No problem,
glad you got it sorted out! :D
Users browsing this forum: Yahoo [Bot] and 3 guests
