Use of library
Use of library
Postby plgarcia » Sun May 20, 2012 10:05 am
I did not found haw to use the library browser.
I can launch it but I have not been able to figure out how to use it. I did not found a user manual to help me to understand. But may by do I have a problem with my installation.
1 - In the File System tab, I can see the folders tree but the bottom pane is always empty.
2 - In the tab Tags I do not understand the logic to select and find an element.
3 - In the tab Tags if I select an icon that is shown at the bottom, and right click "Addto Favorites" Why it does not appears in favorites tabs.
4 - How do we select the element we want to incorporate in our design?
It was quite simple with qcad 2.
Thank you for your help.
Pascal Garcia
plgarcia
Re: Use of library
Postby plgarcia » Sun May 20, 2012 2:44 pm
I have created a bug requested for the use of Favorites.
My system is windows 7 64 bits French.
I think I installed QCad for all users, ans the installation folder is in
C:\Program Files (x86)\QCAD3 Professional\
Can not be this be the problem. I supose that some data is written on the disk and administration rights may be needed !
I tried to run QCAD with administrative rights but does not change anything.
I have two problems that may be the same.
1 - In file system the botom panel stays empty whatever I do (double click, or not)
2 - The favorite problem
The drag and drop works fine, thank you, but I can only take the objectss listed in the Tags tab as nothing else is working.
Regards
plgarcia
Re: Use of library
Postby plgarcia » Sun May 20, 2012 3:53 pm
No it did not change anything.
I copied also the Library folder to my desktop and ensure about permissions, change the configuration to point on this new folder and ask for a rescan at next start up. Same problem.
At this stage the library browser is nor really usable on my system.
I have to go now to the pet shop (it is Sunday :D ), and after if you are interested I can make some more tests and eventually share the screen (via skype or mikogo). I can also install qcad on a other PC (XP professional) if you find it could be of any interest.
Regards
plgarcia
Re: Use of library
Postby plgarcia » Sun May 20, 2012 5:52 pm
Ok I solved the problem.
I Deinstall QCad 2, and QCad 3.
I remove C:\Users\pgarcia\AppData\Roaming\RibbonSoft folder.
Then I reinstall QCad 3, and it works. I really did nothing special when I installed QCad 3, but changing the installation folder not to conflict with QCad 2 installation.
All problems came probably to that double installation and double run as I was swapping between the two versions.
Regards
plgarcia
Re: Use of library
Postby plgarcia » Sun May 20, 2012 7:52 pm
I did not say anything about it, I read somewhere on the site that this double installation was possible, and I did not think it was of interest.
Your las post said that it was working with W7 64bits.
Then I decided to install from scratch. But again I did not do anaything special while installing the first time.
If you want me to make some other tests reinstalling qcad 2 and after qcab 3 and see if the problem occurs it is possible (not tonight!).
Regards
plgarcia
Re: Use of library
Postby plgarcia » Mon May 21, 2012 5:48 am
Hello
there is a confusion. I have not been clear enough. I changed location for Qcad 3. No way to have them both working if we do not do this.
Sometime I will make a test as I proposed with the two versions installed, just to know if this double installation was the reason.
Regards
Pascal Garcia
plgarcia
Re: Use of library
Postby plgarcia » Mon May 28, 2012 4:02 pm
I do not know what went wrong with my first installation.
All installation tests I made did not allow to reproduce the the problem.
I give up for this sorry!
Regards
Pascal
plgarcia
Re: Use of library
Postby plgarcia » Tue May 29, 2012 7:01 am
Yes everything works fine. And I have not been able to find a way to reproduce the problems I had.
The procedure to solve the problem was to uninstall QCad and reinstall.
Thank you for the help you provide.
I logged a new bug I found on intersections between ellipses not detected.
I logged also a resquest for a warning message when an operation is blocked because a layer is locked. I lost some time to find why QCad was suddenly not fonctionning, I accidently locked the current layer.
I add a comment on the autosave feature request. This feature does not behave well and causes security issues.
Globally QCad3 is a very good improvement of QCad2.
Regards
Pascal Garcia
plgarcia
