csv import
TheEnglishPatient
csv import
Postby TheEnglishPatient » Sat Jun 16, 2012 4:55 pm
Is there an utility/option to import (a large number!) of xyz coordinates into Qcad 3.0? They come originally from a .kml file, and I recognise that a direct import would be probably too much to hope for, but I could make an intermediate csv file or such like. I don't need all the fancy stuff, just the raw points/lines in the dxf. Alternative, what is the minimal dxf into which I could copy/paste my coordinates - there is some thread in the 2.0 forum to this effect, but it does not work under 3.0/Win7 (or I am too thick to do it).
Any help appreciated.
Re: csv import
Postby andrew » Sat Jun 16, 2012 6:12 pm
Note that with QCAD being 2D, only X/Y coordinate pairs can be imported (no Z).
Depending on your programming skills, you could write a small import script that parses the KML (Keyhole Markup Language?) file and inserts the points into the current or a new drawing.
With KML being an XML dialect, I would recommend using the Qt QXmlSimpleReader / QXmlDefaultHandler classes to read the file.
QCAD 3 final will come with an example script that imports point pairs from a file in the simple format:
x1,y1
x2,y2
x3,y3
You can install and use this script also with QCAD 3 RC5:
Installation:
- Quit QCAD
- Download the attached ZIP file
- Extract its contents to your QCAD installation directory into sub folder scripts/Examples
- This creates folder scripts/Examples/IOExamples/ExImportPoints
Usage:
- Start QCAD
- Choose menu Examples - Import / Export - Import Points
- Choose any file in the x,y format described above and click OK
- QCAD inserts a point entity for every line in the file containing an x,y coordinate. Other lines in the file are ignored.
IOExamples.zip
(2.74 KiB) Downloaded 276 times
TheEnglishPatient
Re: csv import
Postby TheEnglishPatient » Sat Jun 16, 2012 7:08 pm
Brilliant!
You are right about the z of course, it's in the kml but as I am doing some extensive geometry manipulation (curve fitting etc) in a separate program in between anyway, no problem to get to a simple flat x,y points file.
Now, ideally, it would also be nice to be able to import in a similar way lines etc...
However, in any case thanks very much for the present solution and the prompt answer!
hungerburg
Re: csv import
Postby hungerburg » Wed Jun 20, 2012 9:43 am
TheEnglishPatient wrote:Now, ideally, it would also be nice to be able to import in a similar way lines etc...
There is an ascii notation for this, its called SVG. QCAD already handles a subset of known entities.
Re: csv import
Postby andrew » Wed Jun 20, 2012 10:19 am
Good point, SVG import should indeed work for lines, arcs, circles, rectangles, ellipses, polygons, polylines and paths.
Unfortunately, point shapes are not supported by SVG as far as I know.
Note that the default SVG coordinate system is screen oriented (Y increases downwards), so Y coordinates are negated by QCAD on import.
Example SVG file for a line:
<svg xmlns="http://www.w3.org/2000/svg" version="1.1">
  <line x1="0" y1="0" x2="200" y2="200" />
</svg>
To import SVG files into QCAD, use the menu File - SVG Import.
Users browsing this forum: Bing [Bot], Google [Bot] and 3 guests
