Relative Angle Line Placement
Postby wildspidee » Mon Mar 04, 2013 2:30 am
When creating a line based on a relative angle it seems to default to a middle Reference Point on the line being added. Is there any way to change that to Start or End?
I need to place one start/end of the new line on the start/end of the relative line specifying the length. As it is, I have to double the length, place it in the middle and then remove the excess.
Thank you.
wildspidee
Re: Relative Angle Line Placement
Postby andrew » Mon Mar 04, 2013 8:45 am
Thanks for your suggestion. A feature request has recently been added for this issue:
http://www.ribbonsoft.com/bugtracker/in ... ask_id=773
Postby Clive » Mon Mar 04, 2013 4:20 pm
Hi
For now is it possible to use the Copy and Paste tools for your situation?
1. Select line.
2. Copy with reference.
3. Choose reference point - End/start.
4. Then - using the Paste tool, edit the rotation as required and place the line.
Edit:
I forgot to mention that you will need to change the length afterwards in the property editor!
Moderator / Drawing Help
Postby wildspidee » Mon Mar 04, 2013 5:44 pm
Clive,
Excellent work around. I gave it a try and it will certainly suffice. The only issue is the length change. I can't do it with the Property Editor, as it comes off the wrong end. I used the Lengthen/Shorten tool and that worked great.
I had never used the Copy with Reference before. That's a handy little thing. For such a seemingly simple program, there seems to be a tool for everything. I just have to find it!
Thank you.
wildspidee
cron
