Adding PDF-Export-Button to Toolbar
caigner
Postby caigner » Sat Apr 20, 2013 11:36 am
Hi!
I would like to add a PDF-Export-Button to the main toolbar on top, next to the Quick SVG export button.
How can I do that?
Thanks,
Christian
[Edit: Topic moved to relevant forum]
Moderator / Drawing Help
Re: Adding PDF-Export-Button to Toolbar
Postby Clive » Sat Apr 20, 2013 2:51 pm
Hi Christian
Currently it is not possible to self define a toolbar, to add an individual tool etc.
However this would make a great feature request - to be able to custom make your own 'user defined' toolbars :wink:
You can add feature requests here:
http://www.ribbonsoft.com/bugtracker/
* You can also use the shortcut command 'XD' which is very convenient.
