How do I lengthen the dimension line?
Posted: Mon Apr 22, 2013 7:45 pm
by caigner
I added a diametric dimension to a circle and wanted to move the number outside the circle. Moving the number was no problem, but the line of the diametric dimension did not "grow" with the moved dimension text.
So here is my question: How do I lengthen the dimension line?
Re: How do I lengthen the dimension line?
Posted: Tue Apr 23, 2013 7:14 am
Hi caigner,
in this case you have to explode the dimension - then you can use the lengthen tool. I think this is just a workaround - but I can't see right now a better solution.
Maybe worth a feature request .....
Posted: Tue Apr 23, 2013 10:22 am
by Clive
In addition:
You will find that when you select or explode/select entities in QCAD ( in this case a dimension entity! ), you will also be able to 'click and drag' a reference point to a new coordinate position.
Before
- Diametric - modify 1.png (2.23 KiB) Viewed 6936 times
After
- Diametric - modify 2.png (4.86 KiB) Viewed 6936 times
Posted: Sat Apr 27, 2013 6:14 pm
by caigner
Thanks! Works well enough. But you are right, it will be a great feature.
