Command Line Focus
zak
Command Line Focus
Postby zak » Fri May 03, 2013 3:57 pm
Is there a way to get the the command line to focus when using shortcut commands? (currently using OSX if that matters) I am coming from ACAD and to be able to just type in commands, including command options such as the first point, second point, radius, etc without having to touch the mouse would be great.
Re: Command Line Focus
Postby andrew » Fri May 03, 2013 4:03 pm
Yes, you can hit the space key (see also menu 'View' - 'Focus on Command Line').
zak
Postby zak » Fri May 03, 2013 5:22 pm
I'm a noob :oops:, I see now. Also focus the option tool bar with Ctrl-Space. I guess it'll take a bit to get used to, it's just a bit awkward until then, plus once I start to understand the UI and the design reasons/choices I'll be rocking.
Thanks, Zak
Users browsing this forum: Baidu [Spider] and 1 guest
