How do I create an ellipse in an Isometric Projection ...
Posted: Mon Jul 01, 2013 7:52 am
I tried to design an ellipse with QCAD Tools - but I stuck .... maybe someone has an easy solution for me
Case: Imagine a model wall build with round dowels - like a Blockhouse,
Now I have to cut the top round dowels under 30° to get a gable shape,
In an isometric this cut has to appear like an ellipse on both sides,
Right side was easy to do with QCAD - maybe not absolutely correct but good enough
Left side .... a disaster
I have no idea how I can make it correct looking
- Husky-2013.06.30-01.png (7.76 KiB) Viewed 11090 times
A square dowel shape is used as the construction base in the isometric.
I know how to design a correct ellipse step by step - that is not what I'm looking for! I'm looking for a fast and "just good enough looking" solution in QCAD!
Any Ideas?
Re: How do I create an ellipse in an Isometric Projection ..
Posted: Mon Jul 01, 2013 10:29 am
by Clive
Hi Husky
Do you mean something like this ?
- Dowel example.png (2.8 KiB) Viewed 10949 times
Posted: Mon Jul 01, 2013 7:01 pm
YES! Nice!!! How???
I'm to dummzumzum!
Posted: Mon Jul 01, 2013 7:34 pm
by Clive
Well, ideally we need some additional options in the ellipse tools to produce something like this easily!
So... for me I didn't use the ellipse tool, I instead used the Spline (control points - sp) tool, which to be honest with an 'oblique' rectangle as you have here, is a lot easier to achieve something that resembles an elliptical shape.
This is how I done it - it's not straight forward but it does get the job done for now.
1.First make a grid.
2.Use the Spline tool (control points) and fit to the grid intersections.
3.Copy and paste the rest where you need them.
- elliptical shape.png (52.36 KiB) Viewed 10923 times
Posted: Tue Jul 02, 2013 3:40 am
Nice, thanks a lot! The grid was the trick
clive wrote:Well, ideally we need some additional options in the ellipse tools to produce something like this easily!
Yep - that would be nice! But I'm sure - we have just to sit tight ...
Posted: Fri Aug 16, 2013 8:32 pm
Husky wrote:Yep - that would be nice! But I'm sure - we have just to sit tight ...
And here it is!
The new QCAD update - 3.2.1 - has a new tool what solves problems like this with just a few mouse-clicks. Perfect!!!
The new tool is called:
"Ellipse: Inscribed in quadrilateral (tangential to four lines) (EQ)"
- Husky-2013.08.16-07.png (3.85 KiB) Viewed 10834 times
You have to try it by yourself!
Posted: Tue Aug 20, 2013 4:54 pm
by Clive
Husky wrote:You have to try it by yourself!
' Yippe kay yay'
Yes what an excellant tool, I've been playing around with it...so very useful, especially for isometric work
Have you also noticed the extra Circle 'geometry' tools:
Main menu > Misc > Drawing...
- Misc > Drawing .png (18.66 KiB) Viewed 10654 times
Posted: Tue Aug 27, 2013 10:42 pm
clive wrote:Have you also noticed the extra Circle 'geometry' tools:
Yes I have - but the absolute winner for me is:
Modification tools: Clip selection to rectangular area.
- Husky-2013.08.27-03.png (15.49 KiB) Viewed 10725 times
Be a little creative, play in combination with this tool also with the clipboard and you can see how powerful this tool is!!!
