Learning with the Included Examples
Posted: Wed Aug 28, 2013 1:49 am
by wildspidee
I see that the new version of QCAD has a lengthly list of items under Examples in the main menu. The Reference Manual does not appear to have any mention of these examples and their functionality. I opened the .js files, but there aren't really any comments in there to help.
The QCAD Application Framework pages have some tutorials, but don't list all of them included in Examples.
Is there some documentation somewhere that explains all of the examples, what they do and how they do it? I'm working on a big project and these are a great place to start.
Thank you for your time and assistance.
Re: Learning with the Included Examples
Posted: Wed Aug 28, 2013 9:44 am
There is no documentation other than the one included in the source code for the 'Misc' folder and examples at this point.
Note that you also have the source code of all other QCAD tools available and most likely you can start your new tool by copying the code of a similar, existing tool.
Posted: Wed Aug 28, 2013 3:54 pm
by wildspidee
Okay, I'll have to figure out the examples from their source. May I ask where this "Misc" folder is located?
My goal is to build a system that creates full drawings from the command line with no UI interaction. If you happen to have an example somewhere that is more extensive than CreatingDrawing.js, I'd love to have a look at it.
In some programs, there is a log file that records all the calls made when someone is using the UI. Is there such a file being generated in QCAD? This would allow me to draw something specific and then check the log file for what the program did on the back end. I could piece it together from there.
I started and then abandoned this project a year ago, but this time I'm going to follow through. QCAD is critical to my goals. Any suggestions are welcome.
Thank you for your time.
Posted: Thu Aug 29, 2013 6:09 am
by J-J
I remember posting a similar question back at the time of QCAD 2, to have a macro recorder as you have in EXCEL...
Posted: Thu Aug 29, 2013 11:23 am
by Clive
J-J wrote:I remember posting a similar question back at the time of QCAD 2, to have a macro recorder as you have in EXCEL...
Yes, I agree, I would like to see something like this for QCAD too.
