Printing multiple sheets
Postby neshen » Fri Oct 18, 2013 1:16 pm
Thanks for all the useful tips. Just got the pro version this week, its really a nice software. I have a question regarding the printing. I have drawn a component with several views to a scale of 1:1 on a single sheet. I have inserted a template for each view I want and scaled it accordingly to fit around the drawings. But when am doing print preview, and select multiple pages, the pages are aligned while my drawing are scattered all over the drawing space. How can I place each of the drawings I got on a sheet. Also is it possible to have different scale, for example If a want to show a zoomed view of part of the component. It is possible to do all than within a single file.
Kind Regards,
Neshen
neshen
Re: Polar tracking in QCAD
Postby J-J » Fri Oct 18, 2013 1:57 pm
Hi Neshen,
Did you know that within "print preview" you have the possibility to manipulate your drawing entities, i.e. "move, rotate, scale..."", you may then position your different views as you wish.
see tutorial: viewtopic.php?f=47&t=2542
Note: it is better to create a new topic when you have a question on a different subject
JJ
JJ
J-J
Moderator
Users browsing this forum: Bing [Bot] and 4 guests
