How to change dash line scale
Postby neshen » Thu Oct 24, 2013 1:00 pm
hi,
I have a drawing which is quite big. All the dashed lines in the drawings appear as solid lines. How can I change the scale of the dashed lines so that it is visible. Is there an option such as ltscale as in autocad??
neshen
neshen
Re: How to change dash line scale
Postby andrew » Thu Oct 24, 2013 1:11 pm
Please read my blog post from yesterday about this exact problem and a potential solution in the new QCAD 3.4:
http://qcad.org/en/139-a-new-view-mode
LTSCALE is also available under:
Edit - Drawing Preferences - General - Linetype - Global Linetype Scale
I would only recommend to adjust LTSCALE if you wish to adjust the line pattern density for prints / in print preview. To work in model space, the new view mode can be used instead (see blog post above).
Postby banzai » Wed Apr 27, 2016 1:54 am
Awesome!!
I had this exact problem. Drawing a floor plan for a house and using mm as my base unit. All dashed lines appear as solid. For those who want to skip ahead without reading the blog;
click "view/screen based line types"
But go and check Andrews' blog out. It explains the issue well.
~Debian Linux, QCAD V3.7.5.0 (3.7.5) Qt Version 4.8.4~
banzai
