Getting started with CAM add-on
Postby cmcgrath5035 » Fri Oct 25, 2013 1:26 pm
I recently added CAM to my QCAD 3.4.0 (Linux openSUSE 12.3)
Started by experimenting with a simple drawing (circle and line) to experiment with GCode process.
Selecting CAMExport shows the command in the command window, but nothing seems to happen.
I am moderately familiar with GCode, never used CAM-Expert.
Pointers please to some documentation of some sort.
cmcgrath5035
Re: Getting started with CAM add-on
Postby andrew » Fri Oct 25, 2013 6:48 pm
Thanks for your report. This has been fixed in the latest release (3.4.2). You can download it from your download area:
https://www.ribbonsoft.com/shop/history.php
Postby cmcgrath5035 » Fri Oct 25, 2013 7:11 pm
Thanks, I now see the config window and can move forward figuring things out.
cmcgrath5035
Postby cmcgrath5035 » Sun Oct 27, 2013 1:35 pm
I have been reading thru the doc folder under camexpert.
Is there a way to access CAM Simulation under the QCADCAM 3.4.2 combined package?
cmcgrath5035
Postby andrew » Sun Oct 27, 2013 4:30 pm
Simulation is experimental (work in progress) but has meanwhile been improved. I expect to have a stable simulation tool for the next release.
