Accessing the options toolbar
Postby andrew » Wed Dec 11, 2013 6:53 pm
From a QCAD user:
When creating lines I cannot use the tab key to change the dimension, I have to move the mouse to that box and click in it to be able to change the dimension.
Re: Accessing the options toolbar
Postby andrew » Wed Dec 11, 2013 6:57 pm
I'm assuming that you want to access the options tool bar at the top to enter for example the length and angle of a line that is created using the tool
Draw > Line > Line from Angle
The shortcut to access the options tool bar is:
^Space (that is Ctrl + Space)
This gives keyboard focus to the first item in the options tool bar. You can then use tab to move to the next item, etc.
