Same size for draw and its print
Postby rhenxoff » Thu Jan 16, 2014 12:53 am
Maybe this question has been solve, but i am urged for a solution. I go to draw a template for later be used to build it on a plastic surface, so i need the dimensions in the draw be exactly the dimensions printed over a blue paper. How acomplish this task?
Thanks.
rhenxoff
Re: Same size for draw and its print
Postby andrew » Thu Jan 16, 2014 9:57 am
First, create your drawing in real measures as always (1:1).
When it comes to printing, print your drawing in real measures too (1:1).
You can adjust the scale of your drawing in the print preview at the top. Make sure the "Scale" is set to "1:1".
Users browsing this forum: Yahoo [Bot] and 2 guests
