How to clean double lines in a drawing ...
Postby Husky » Tue Feb 11, 2014 8:07 pm
if I use a move and copy command to get a desired pattern - most of the time the result will have many stacked lines. :cry:
If I like to use this file for a CNC machine I need to clean this drawing.
The tool "Detect duplicates" works nice for identical duplicates but how can I find and delete shorter lines which are located in the same place as the longer lines?
This selection shoes 6 lines - it should be just two long lines! I only need the longer lines ... :shock:
Test-Verbundpflaster.dxf
(645.25 KiB) Downloaded 130 times
Moderator / Drawing Help
Re: How to clean double lines in a drawing ...
Postby Clive » Tue Feb 11, 2014 9:12 pm
Hi Husky
Try this:
1.Use the selection filter tool and set up the fields correctly - set the tool to find all lines 35mm long. Then choose 'Replace the current selection.
pic 1.png (10.45 KiB) Viewed 2391 times
2.Using the property editor, move the selection to a new 'temporary' layer.
pic 2.png (17.8 KiB) Viewed 2391 times
3.Now delete the selection or delete the layer.
pic 3.png (1.55 KiB) Viewed 2391 times
4. Now use the 'detect duplicates' tool again and clean up the file, it should now detect all duplicate 70mm long lines, which you can delete - leaving the file clean for your job :wink: .
Postby Husky » Wed Feb 12, 2014 8:09 am
Shoot, I forgot the Selection Filter tool! :oops:
Works perfect - thank you clive! :D
