Manage multilayers files.
Luizinho
Post by Luizinho » Tue Mar 18, 2014 7:38 pm
I´m new with QCAD and I´m running the trial version. Just checking some features.
I´m working with a *.dwg file wich contains a lot of layers (as much as up to 90).
Is there any option to make a layer multiselection instead of removing them one after another???.
I´m been searching in the forum but didn´t find any answer to this problem.
Thanks beforehand everyone.
Força!!
Lz.
Re: Manage multilayers files.
Post by andrew » Tue Mar 18, 2014 7:45 pm
No there is no such function in QCAD.
However, you can delete the entities on those layers first and then remove all empty layers at once using the tool:
Layers > Purge Unused Layers
Moderator
Post by Clive » Tue Mar 18, 2014 8:58 pm
Hi Luizinho and welcome
This is a problem I know all too well, one trick I sometimes do when I receive such files is to first turn off all the layers then only turn on the layers you want to keep (this could also be a chore in itself :x ), after this, select everything in the visible layers and copy them (Main Menu - Edit - Copy), then start a new drawing and paste everything in, this should also preserve the layers you wanted to keep ... but without all the unwanted layers.
Luizinho
Post by Luizinho » Wed Mar 19, 2014 9:17 am
Ok, thank you!!
I asked just in case. I had figured out it wasn´t possible.
Clive, I followed your advice in this particular case.
Good morning and have a nice day!
:wink:
Moderator
Post by Clive » Wed Mar 19, 2014 10:02 am
Luizinho wrote:Is there any option to make a layer multiselection instead of removing them one after another???.
There is already an existing feature request for this, if you add a vote for it, this will help the request get noticed and hopefully be considred for implementation :wink:
You will need to register on the Bugtracker (which is also used to add feature requests).
See here:
http://www.ribbonsoft.com/bugtracker/in ... &closedto=
Luizinho
Post by Luizinho » Wed Mar 19, 2014 3:56 pm
I did and I hope so.
Thanks Clive!!
Sometimes it´s real a mess to deal with so many layers e_confused
