Dimension length
Dimension length
Postby Frank60 » Wed May 14, 2014 5:38 pm
How do I read/edit a dimension's length in the property editor?
Frank
Frank60
Re: Dimension length
Postby andrew » Wed May 14, 2014 10:06 pm
Good point. Currently, you can only see the measured value in the drawing and only if the label is not overwritten with a fixed text and the linear factor is 1.
I've made this property visible as read-only property for the next release:
Screen Shot 2014-05-14 at 23.00.29.png (13.37 KiB) Viewed 2973 times
Postby Clive » Fri May 16, 2014 9:47 am
andrew wrote:I've made this property visible as read-only property for the next release:
Just curious Andrew, why only 'read only' ? - wouldn't it be useful if one could edit also?
Edit: I understand the reasons for dimensions to be grouped as it were, but maybe an option in the property editor to explode any dimension would be useful, then the text only could be edited! It would save a trip to the standard explode command in such circumstances.
Moderator / Drawing Help
Postby Frank60 » Tue May 20, 2014 7:26 am
Excellent, I would also like to be able to edit the length to enter exact dimensions from older paperdrawings.
Thanks,
Frank
Frank60
Postby Husky » Tue May 20, 2014 8:22 am
Clive wrote:I understand the reasons for dimensions to be grouped as it were, but maybe an option in the property editor to explode any dimension would be useful, then the text only could be edited! It would save a trip to the standard explode command in such circumstances.
Hi Clive - why I have to explode a dimension to be able to edit the text? Is the Label function in the Property editor not enough to get it done ... without an "extra trip"?
Postby Husky » Tue May 20, 2014 8:40 am
Hi Frank,
Frank60 wrote:Excellent, I would also like to be able to edit the length to enter exact dimensions from older paperdrawings.
You are already able to overwrite a dimension value in the Property editor. Just select the dimension, go to the property editor and put the desired value in the "Label" Field.
Postby Husky » Tue May 20, 2014 8:42 am
Nice!!! :D
Postby Frank60 » Tue May 20, 2014 9:50 pm
Husky wrote:Hi Frank,
Husky, thanks for the help.
But....I do not want to edit the text/label, but the length/measurement itself. Enter a value and the dimension changes to this new value. This is standard in practically all CAD and drawing programs. In QCAD this is already possible for lines, but not for dimensions.
In QCAD the only way to change a measurement now is graphically.
Thanks,
Frank
Frank60
Postby andrew » Tue May 20, 2014 10:02 pm
Frank60 wrote:But....I do not want to edit the text/label, but the length/measurement itself. Enter a value and the dimension changes to this new value.
Please consider the following simple drawing:
Screen Shot 2014-05-20 at 22.58.24.png (9.65 KiB) Viewed 2875 times
Let's say the user changes the measurement of the dimension from 20 to 25 using the property editor. Which of the three options below (or anything else) would be the expected result and with what reasoning behind it?
Screen Shot 2014-05-20 at 22.58.40.png (9.76 KiB) Viewed 2875 times
Screen Shot 2014-05-20 at 22.58.51.png (10 KiB) Viewed 2875 times
Screen Shot 2014-05-20 at 22.59.17.png (10.09 KiB) Viewed 2875 times
I cannot find this functionality in any of the CAD systems I have access to. Can you point me in the right direction? Thanks.
This is a fair point. If that logic is applied to the example above, the first option would be the one you would expect.
To me, changing the length of a line seems more natural (clearly, the end point moves) than changing the 'length' or dimension of a dimension entity somehow. But maybe that's just me.
Postby Husky » Wed May 21, 2014 9:15 am
I get the feeling that I understand you now ..... :wink:
You are looking for something like this ...
.... and you like to change the shape of this rectangle just with editing the "Dimension Values" , right?
Unfortunately this screen shot (not from QCAD!) doesn't shows a real dimensioning - it shows only the changeable dimension of this rectangle during the construction of this rectangle. And yes - you can change this shape any time later but it has nothing to do with a normal dimensioning in a drawing ....
Could it be that we are now on the same page?
Postby Clive » Wed May 21, 2014 11:23 am
Editing the actual dimension size is what I meant and not the text label, sorry for confusion.
Frank60
What you are looking for is not currently available in QCAD ... yet! But the option to dynamically change dimension sizes as you have explained would definitely be welcome.
Please feel free to add a feature request here: http://www.ribbonsoft.com/bugtracker/
QCAD is in my opinion by far the best straight forward 2D CAD program out there,its strength is the strong set of editing/modifying and all round geometrical drafting tool sets
and of course Andrews steadfast commitment to development.
Postby Frank60 » Wed May 21, 2014 5:54 pm
Andrew, Husky, Clive,
Yes for me the first option, the endpoint changes.
Visio, Corel Draw, TurboCAD, all serious 3D programs Creo, Alibre have this feature. I have never used Autocad much but I remember that anything could be done from the command line including changing dimensions.
My drawing process may differ from yours. I first take measurements of existing objects (parts of boats) and then make a 2D drawing of them to be able to reproduce them on our router. That means sometimes that I have to draw a line, circle, rectangle, whatever at xxxx.xx mm from a point, line, object, whatever. I then first draw a dimension, change it to the required length (only graphically now with a lot of zooming in and out and scrolling the screen to read the value) and then draw the line through the endpoit of the dimension. I also use construction lines to do this and I miss these in QCAD too.
It would save tons of time to change the length in the property editor. Also the accuracy would improve vastly (label reading errors).
Thanks,
Frank
Frank60
Postby Husky » Wed May 21, 2014 7:20 pm
Clive wrote:Husky
Don't worry about that ...... I'll survive your attack :D :D :D
Postby Husky » Wed May 21, 2014 8:28 pm
Hi Frank - thanks for explanation.
I understand what you are looking for and it would be nice to have something like that in QCAD. But honestly I see a couple obstacles to realize that in QCAD because the 2D concept is different than a 3D concept for CAD Programs. But maybe Andrew has already a solution in the drawer ....
However, till then you maybe like to test different ways in QCAD instead this zooming, scrolling in and out game until the doc comes .... e_surprised
Have you ever tried to adjust (e.g. 10 times bigger) the settings for the Dim Text size just during the construktion process? After it is done you can turn the settings back to normal sizes.
This one is with a DIM Text height: 3.5mm
Same Zoom but with a DIM Text height of 35mm
Or have you ever tried to use the Info tool to doublecheck measurements? Regardless the zoom factor it has always the same, readable size for a taken Measurement.
... or whats about multi Viewports? Same drawing with different section views and zooms
Or last but not least: Would it be possible to create a block (with the Dim!) and scale it then to the right size? Ok - doesn't works with all shapes but a couple of them ...
Yep - understood - I have to stop NOW! :lol: :lol: :lol:
Users browsing this forum: No registered users and 6 guests
