Selecting between overlapping lines in QCAD
Postby newinwit » Sat May 31, 2014 12:50 pm
What's the secret, please?
newinwit
Re: Selecting between overlapping lines in QCAD
Postby Husky » Sat May 31, 2014 4:24 pm
newinwit wrote:What's the secret, please?
No secrets! :wink: What do you need to do?
Postby newinwit » Sun Jun 01, 2014 2:41 pm
If I end up with two or more overlapping lines in the same layer, is there a way to cycle through the different lines in order to select the one I want?
newinwit
Postby Husky » Sun Jun 01, 2014 6:43 pm
newinwit wrote:If I end up with two or more overlapping lines in the same layer, is there a way to cycle through the different lines in order to select the one I want?
Same Layer / same position / same length = no
Same Layer / same position / different length = mostly yes.
Use the "select rectangular area" tool (left to right) to catch the shorter line and with a left mouse click you can catch the longer line.
Picked with the "select rectangular area" tool
Postby J-J » Sun Jun 01, 2014 6:57 pm
try this: viewtopic.php?f=107&t=2142&p=6873&hilit=select+widget#p6873
I keep it under may layer list, it comes in handy sometimes
JJ
J-J
Moderator
Postby newinwit » Sun Jun 01, 2014 7:14 pm
Thanks for the replies. Maybe we can hope for this feature in future releases...? It would be nice if we could somehow "tab" through overlapping lines.
newinwit
Postby Clive » Mon Jun 02, 2014 9:06 am
Hi newinwit
newinwit wrote:Thanks for the replies. Maybe we can hope for this feature in future releases...? It would be nice if we could somehow "tab" through overlapping lines.
I think we already have the means with the selection Filter (pro version) - maybe Andrew can tweak it and add something extra in the 'property' options to help filter the selections with overlapping lines.
Selection Filter.png (7.92 KiB) Viewed 3642 times
Can you expand slightly and possibly submit an example drawing to support your case?
Postby newinwit » Wed Jun 04, 2014 1:01 pm
Hi Clive,
I may be missing something here, but...
Let's say I have an 8" line on top of a 6" line--same layer, color, etc. Thankfully, QCAD does a nice job of letting me know there is more than one line there, but pointing and clicking anywhere on the lines selects the longer one. I understand I can use the rectangular selector to grab only the smaller line. But what if I have small, intricate entities somewhere on my 6" line? My selection rectangle must be very, very skinny in order to select only the line I want. Know what I mean?
newinwit
Postby Clive » Wed Jun 04, 2014 1:37 pm
Okay, presuming you are using QCAD pro -
Heres a line 8" long with overlapping lines of 6",4" and 1/2".
Using Selection Filter 1.png (593 Bytes) Viewed 3579 times
Using the selection Filter, I can set it up so that it will only select the 1/2 " lines, as you can see there are 3 selected.
Using Selection Filter 2.png (6.62 KiB) Viewed 3579 times
Postby newinwit » Wed Jun 04, 2014 3:01 pm
Great. Good solution. Thanks Clive!
newinwit
Postby Clive » Tue Jun 10, 2014 10:42 am
Just been encountering similar situations where I need to select smaller lines overlapped by others and here's another (maybe better) solution for dealing with them.
In my drawing I need to select the red ringed line ... but how do I select only this line?
Selecting overlapping lines pic 1.png (5.65 KiB) Viewed 3520 times
Here's how, by pressing the 'Shift' key on the keyboard (keep held down) I can select any other lines I want to un-select them and then I am left with only the smaller line selected, now I can carry on working and do whatever I need to do to this smaller 'overlapped' line :wink:
Selecting overlapping lines pic 2.png (1.77 KiB) Viewed 3520 times
