Dimensioning
Dimensioning
Postby Graham Wright » Mon Jun 30, 2014 11:01 am
Suddenly, the dimension tools have stopped working.
E.g. - straight horizontal line, when I click on the end points, a rectangle is created.
What am I doing wrong? It has worked perfectly up to now and stored drawings can have dimensions added in the expected fashion.
Have I changed a setting?
Graham Wright
Re: Dimensioning
Postby andrew » Mon Jun 30, 2014 11:20 am
The dimension font and arrows are likely simply too small to be seen in your current drawing.
Please refer also to our FAQ at:
http://www.qcad.org/en/qcad-documentati ... n_settings
Re: Dimensioning
Postby Graham Wright » Mon Jun 30, 2014 11:49 am
Brilliant! Thank you.
Graham Wright
