QCAD 'construction' lines
Postby sswcharlie » Wed Jul 09, 2014 5:33 am
Is there an option for putting in construction lines for getting items lined up ? Have not foundd as yet. Otherwise I can use a line and delte afterwards.
Charles Harris
Re: QCAD 'construction' lines
Postby Husky » Wed Jul 09, 2014 8:07 am
Hi Charles,
yes there are a couple possibility's to line something up - try this one:
Select that what you like to align in your drawing and start the tool "Align". You will find it in the Menu "Modify".
Have a close eye at the options ....
Moderator / Drawing Help
Postby Clive » Wed Jul 09, 2014 11:43 am
sswcharlie wrote:Is there an option for putting in construction lines for getting items lined up ?Charles Harris
Charles, common practice with all CAD drafting is to use different layers, for example set up a layer specifically for construction lines, select this layer in the layer list and draw what you need (construction lines, points etc.), when done make layer invisible (eye icon) if needed (particularly when printing out your master piece).
layer list example.png (5.23 KiB) Viewed 1914 times
have a look here for more info about layers:
Recently the option to use Xlines and Rays (infinite lines used for construction purposes) has been added to QCAD, read here to find out more:
