DXF File load but empty
Postby beleneglorion » Mon Jul 21, 2014 12:49 pm
hi
a client send me a lot of dxf file, some work well in qcad other just open without error but nothing is shown on screen ...
i have join 2 files , both done with the same software, from my client, both can be open without error in libreCAD.
i use :
QCAD
Version: 3.5.1.4 (3.5.1.4)
Build Date: Jun 5 2014
Qt Version: 4.8.4
Compiler: gcc 4.4.3
Systeme
Linx Ubuntu 64bit saucy
best regards
work.DXF
this file works fine
(79.61 KiB) Downloaded 57 times
nook.DXF
this is load on QCAD but empty
(140.24 KiB) Downloaded 59 times
beleneglorion
Re: DXF File load but empty
Postby andrew » Mon Jul 21, 2014 1:07 pm
The drawing nook.dxf has been entirely created in a paper space (block "*Paper_Space").
If you switch to this block after loading the file, you can see the drawing:
Screen Shot 2014-07-21 at 14.06.41.png (140.45 KiB) Viewed 1417 times
Note that the lines are also relatively dark, so they might be difficult to see on a black background.
Postby beleneglorion » Mon Jul 21, 2014 2:20 pm
i feel stupid missing that ... :(
i have notice tools missing with the merge tool where product some product doesn't appear on the output file
thxs for the quick reply ...
beleneglorion
Users browsing this forum: No registered users and 6 guests
