What is the "Meta Grid"?
careysub
Post by careysub » Fri Aug 29, 2014 8:22 pm
Neither the Reference Manual or the offical QCad book mention this thing, but there are options to set its spacing. What does it do? What effect does setting Meta Grid spacing in Drawing Preference have?
Moderator
Re: What is the "Meta Grid"?
Post by Clive » Fri Aug 29, 2014 10:39 pm
Examples:
Units set to Millimeters.
Example 1
Meta Grid set to 100
Distance between grid points = 10
Meta grid example 1.png (4.5 KiB) Viewed 5163 times
Example 2
Meta Grid set to 1000
Distance between grid points = 100
Meta grid example 2.png (3.17 KiB) Viewed 5163 times
careysub
Post by careysub » Sat Aug 30, 2014 3:02 pm
Thanks.
So this is display only user-reference thing, it does not affect drawing behavior in any way?
Moderator
Post by Clive » Wed Sep 03, 2014 8:57 am
careysub wrote:Thanks.
Changing the Meta grid will not affect your actual drawing behaviour no! only the grid point distances in relation to the unit size you choose to use.
