I want to resize a bar e.g. 300 mm long down to 100 mm on the drawing, but keep the
300 mm value as the length value.
Is that possible?
Thanks in forward
ostene
Resize an object without scaling down whole object
Re: Resize an object without scaling down whole object
You can override the value / label of dimensions in the property editor (property "Label").
- Screen Shot 2014-09-12 at 15.05.44.png (190.73 KiB) Viewed 4072 times
