Cannot open QCAD in linux mint 16
bfairey
Post by bfairey » Sun Sep 28, 2014 2:32 am
Nothing too technical, please.
I've downloaded QCAD but I cannot open it. Terminal went thru its contortions ie lots of dots and rows of data?
It even gave me a logo on the desktop, but wont open.
Brian.
ps Librecad is too basic and Blender too complicated but both opened with no problem.
Moderator
Re: Cannot open QCAD in linux mint 16
Post by Clive » Sun Sep 28, 2014 10:26 am
Hi bfairey and welcome to the forum.
Did you set permissions to run QCAD?
Try 'right - clicking' the desktop icon and select 'properties', then in the dialog that opens go to the permissions options and set Execute -'Allow executing file as program'.
bfairey
Post by bfairey » Sun Sep 28, 2014 1:34 pm
Thanks Clive but no thanks, nothing not a smigin?
Brian. :cry:
Post by andrew » Sun Sep 28, 2014 1:47 pm
One of the most common problems under Linux is that the wrong package is installed. 32 bit on a 64 bit Linux or vice versa. Note also that launching QCAD on a terminal will more likely give you some kind of error to work with.
