Artefacts round hatched surfaces
Learnincurve
Post by Learnincurve » Wed Oct 01, 2014 10:36 am
When hatching surfaces I am getting artefacts around some of the edges. These seem to vary in size and are particularly intrusive on one drawing.
I suspect that the problem may have to do with the way I have set up my dimensions as the hatching in question needs to be at a very low scale to look right:
AR-RSHKE at 0.0007 scale.
I attach a sample drawing and a pdf printout.
Vest_mTak.pdf
(126.39 KiB) Downloaded 404 times
Vest.dwg
(39.49 KiB) Downloaded 400 times
Re: Artefacts round hatched surfaces
Post by andrew » Wed Oct 01, 2014 1:18 pm
Thanks for your report and files.
This is related to bug #1101 and has been fixed for the next release:
http://www.qcad.org/bugtracker/index.ph ... sk_id=1101
For now, you can change the point display mode, for example to invisible:
Edit > Drawing Preferences > General > Point Display
Learnincurve
Post by Learnincurve » Wed Oct 01, 2014 2:37 pm
Thank you very much for your response.
BR
Marius
Learnincurve
Post by Learnincurve » Tue Oct 07, 2014 12:36 pm
I have tried setting the point display in drawing preferences to Mode:1, Size:0 (invisible). The problem is reduced but not altogether solved (please see .pdf printout of affected drawing).
When can we expect the version with a fix for this?
Best wishes
Marius
D_107_Nord.pdf
.pdf with artefacts around roof hatching.
(178.08 KiB) Downloaded 389 times
Post by andrew » Thu Oct 16, 2014 3:58 pm
The next release (3.7.0) is scheduled for later this month.
Learnincurve
Post by Learnincurve » Wed Nov 05, 2014 8:42 am
Thanks Andrew. I now have 3.7.0
